74150 TTL 16选1数据选择、多路开关
消耗积分:10 | 格式:rar | 大小:47 | 2009-08-08
分享资料个
These data selectors/multiplexers contain full on-chip
decoding to select the desired data source. The DM74150
selects one-of-sixteen data sources. The DM74150 has a
strobe input which must be at a LOW logic level to enable
these devices. A HIGH level at the strobe forces the W output
HIGH and the Y output (as applicable) LOW.
The DM74150 features an inverted (W) output only.
评论(0)
发评论
下载排行榜
