AD8397,pdf datasheet (High Out
消耗积分:5 | 格式:rar | 大小:554 | 2009-09-02
vinww特烦恼
分享资料个
The AD8397 has two voltage feedback operational amplifiers capable of driving heavy loads with excellent linearity. The common-emitter, rail-to-rail output stage surpasses the output voltage capability of typical emitter-follower output stages and can swing to within 0.5 V of either rail while driving a 25 Ω load. The low distortion, high output current, and wide output dynamic range make the AD8397 ideal for applications that require a large signal swing into a heavy load.
评论(0)
发评论
下载排行榜
