ADUC836,pdf datasheet (ADCs wi
消耗积分:5 | 格式:rar | 大小:668 | 2009-09-04
打马过草原
分享资料个
The ADuC836 is a complete smart transducer front end, integrating
two high resolution ?-? ADCs, an 8-bit MCU, and program/data
Flash/EE memory on a single chip.
The two independent ADCs (primary and auxiliary) include a
temperature sensor and a PGA (allowing direct measurement
of low level signals). The ADCs with on-chip digital filtering and
programmable output data rates are intended for the measurement
of wide dynamic range, low frequency signals, such as those
in weigh scale, strain gage, pressure transducer, or temperature
measurement applications.
评论(0)
发评论
下载排行榜
