开源硬件-PMP21513.2-适用于音频应用的 25/50W 反激式 PCB layout 设计
消耗积分:0 | 格式:pdf | 大小:539.8KB | 2009-09-06
分享资料个
The quasi-resonant flyback design is a dual output converter with a 24 Volt output and a 6 Volt output. The voltages that are supplied are important for supplying power in audio applications. The design is very low noise for sensitive audio signals with less than 2.5 % voltage ripple on the 24 V (...)
评论(0)
发评论
下载排行榜
