MAX2654/MAX2656 pdf datasheet
消耗积分:2 | 格式:rar | 大小:777 | 2008-06-30
贾永世
分享资料个
The MAX2654/MAX2655/MAX2656 high third-order
intercept point (IP3), low-noise amplifiers (LNAs) are
designed for applications in GPS, PCS, WLL, and satel-
lite phone systems. The MAX2654/MAX2655/MAX2656
incorporate on-chip internal output matching to 50Ω,
eliminating the need for external matching components.
A shutdown feature in the MAX2654/MAX2655 reduces
operating current to 0.1µA, eliminating the need for an
external supply switch.
The MAX2654 operates in the GPS frequency of
1575MHz with 15.1dB of gain, 1.5dB noise figure, and
only consumes 5.8mA. The MAX2655 is designed with
high-input IP3 to improve operation in cellular applica-
tions where the cellular power amplifier leaks into the
GPS receiver. The MAX2656 is designed for PCS
phone applications with 13.5dB of gain in high-gain
mode and 0.8dB of gain in low-gain mode (selected by
a logic control) and 1.9dB noise figure.
The IP3 of MAX2655/MAX2656 is adjustable by a single
external bias resistor (RBIAS), allowing supply current to
be optimized for a specific application.
The MAX2654/MAX2655/MAX2656 operate from +2.7V
to +5.5V single supply and are available in the minia-
ture 6-pin SC70 package.
________________________Applications
GPS Receivers
GPS Receivers in Cell Phones
DCS/PCS Cell Phones
Satellite Phones
Wireless Local Loop
评论(0)
发评论
下载排行榜
