AD5370,pdf datasheet (Serial Input, Voltage Output DAC)
消耗积分:5 | 格式:rar | 大小:554 | 2009-09-18
385288
分享资料个
The AD53701 contains forty 16-bit DACs in a single 64-lead LFCSP and a 64-lead LQFP. The device provides buffered voltage outputs with a span that is 4× the reference voltage. The gain and offset of each DAC channel can be independently trimmed to remove errors. For even greater flexibility, the device is divided into five groups of eight DACs. Three offset DAC channels allow the output range of blocks to be adjusted. Group 0 can be adjusted by Offset DAC 0, Group 1 can be adjusted by Offset DAC 1, and Group 2 to Group 4 can be adjusted by Offset DAC 2.
评论(0)
发评论
下载排行榜
