ADG3233,pdf datasheet (Logic L
消耗积分:3 | 格式:rar | 大小:554 | 2009-09-25
英雄孤寂
分享资料个
The ADG3233 is a bypass switch designed on a submicron
process that operates from supplies as low as 1.65 V. The device
is guaranteed for operation over the supply range 1.65 V to 3.6 V.
It operates from two supply voltages, allowing bidirectional level
translation, i.e., it translates low voltages to higher voltages and
vice versa. The signal path is unidirectional, meaning data may
only flow from A to Y.
评论(0)
发评论
下载排行榜
