2N7002 pdf datasheet
消耗积分:10 | 格式:rar | 大小:66 | 2008-07-09
张国厚
分享资料个
2N7002 pdf datasheet Absolute Maximum Ratings TA = 25°C unless otherwise noted
Symbol Parameter 2N7000 2N7002 NDS7002A Units
VDSS Drain-Source Voltage 60 V
VDGR Drain-Gate Voltage (RGS < 1 M?) 60 V
VGSS Gate-Source Voltage - Continuous ±20 V
- Non Repetitive (tp < 50?s) ±40
ID Maximum Drain Current - Continuous 200 115 280 mA
- Pulsed 500 800 1500
PD Maximum Power Dissipation 400 200 300 mW
Derated above 25oC 3.2 1.6 2.4 mW/°C
TJ,TSTG Operating and Storage Temperature Range -55 to 150 -65 to 150 °C
TL Maximum Lead Temperature for Soldering
Purposes, 1/16" from Case for 10 Seconds
评论(0)
发评论
下载排行榜
