LM139/LM239/LM339/LM2901/LM330
消耗积分:10 | 格式:rar | 大小:551 | 2009-10-08
vinww特烦恼
分享资料个
The LM139 series consists of four independent precision
voltage comparators with an offset voltage specification as
low as 2 mV max for all four comparators. These were
designed specifically to operate from a single power supply
over a wide range of voltages. Operation from split power
supplies is also possible and the low power supply current
drain is independent of the magnitude of the power supply
voltage. These comparators also have a unique characteristic
in that the input common-mode voltage range includes
ground, even though operated from a single power supply
voltage.
评论(0)
发评论
下载排行榜
