LMP8100,pdf datasheet (Program
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-08
laisvl
分享资料个
The LMP8100 programmable gain amplifier features an adjustable
gain from 1 to 16 V/V in 1 V/V increments. At the core
of the LMP8100 is a precision, 33 MHz, CMOS input, rail-torail
input/output operational amplifier with a typical open-loop
gain of 110 dB. Amplifier closed-loop gain is set by an array
of precision thin-film resistors. Amplifier control modes are
programmed via a serial port that allows devices to be cascaded
so that an array of LMP8100 amplifiers can be programmed
by a single serial data stream. The control mode
registers are double buffered to insure glitch-free transitions
between programmed settings. The LMP8100 is part of the
LMP® precision amplifier family and is ideal for a variety of
applications.
评论(0)
发评论
下载排行榜
