ADC12QS065,pdf datasheet (Quad
消耗积分:2 | 格式:rar | 大小:514 | 2009-10-10
分享资料个
The ADC12QS065 is a low power, high performance CMOS
4-channel analog-to-digital converter with LVDS serialized
outputs. The ADC12QS065 digitizes signals to 12 bits resolution
at sampling rates up to 65 MSPS while consuming a
typical 200 mW/ADC from a single 3.3V supply. Sampled data
is transformed into high speed serial LVDS output data
streams. Clock and frame LVDS pairs aid in data capture. The
ADC12QS065’s six differential pairs transmit data over backplanes
or cable and also make PCB design easier. In addition,
the reduced cable, PCB trace count, and connector size
tremendously reduce cost.
评论(0)
发评论
下载排行榜
