DS90C383/DS90CF384,pdf datashe
消耗积分:5 | 格式:rar | 大小:558 | 2009-10-14
张亮
分享资料个
The DS90C383 transmitter converts 28 bits of LVCMOS/
LVTTL data into four LVDS (Low Voltage Differential Signaling)
data streams. A phase-locked transmit clock is transmitted
in parallel with the data streams over a fifth LVDS link.
Every cycle of the transmit clock 28 bits of input data are
sampled and transmitted. The DS90CF384 receiver converts
the LVDS data streams back into 28 bits of LVCMOS/
LVTTL data. At a transmit clock frequency of 65 MHz, 24 bits
of RGB data and 3 bits of LCD timing and control data
(FPLINE, FPFRAME, DRDY) are transmitted at a rate of 455
Mbps per LVDS data channel. Using a 65 MHz clock, the
data throughputs is 227 Mbytes/sec. The transmitter is offered
with programmable edge data strobes for convenient
interface with a variety of graphics controllers. The transmitter
can be programmed for Rising edge strobe or Falling
edge strobe through a dedicated pin. A Rising edge transmitter
will inter-operate with a Falling edge receiver
(DS90CF384) without any translation logic. Both devices are
also offered in a 64 ball, 0.8mm fine pitch ball grid array
(FBGA) package which provides a 44 % reduction in PCB
footprint compared to the TSSOP package.
评论(1)
发评论
挑灯夜读 2017-11-20
0 回复 举报
谢谢分享,但是在哪里下载? 收起回复
下载排行榜
全部1条评论
