ES211,pdf,datasheet (2 PHASE D
消耗积分:10 | 格式:rar | 大小:455 | 2009-10-19
5762
分享资料个
The ES211, a 1-chip composed of hall sensor and output coil drivers, applied
to 2-phase DC motor. The high sensitivity of Hall Effect sensor is suitable for
motors from mini-type CPU coolers to blowers and DC fans. The device also
include a amplifier that amplifies the Hall voltage, and a Schmitt trigger to provide
switching hysteresis for noise rejection, and complementary open-collector drivers
for sinking large current loads. An internal bandgap regulator is used to provide
temperature compensated supply voltage for internal circuits and allows a wide
operating supply voltage.
评论(0)
发评论
下载排行榜
