TDA8594 pdf datasheet
消耗积分:10 | 格式:rar | 大小:788 | 2008-07-15
分享资料个
1. General description
The TDA8594 is a complementary quad Bridge Tied Load (BTL) audio power amplifier
made in BCDMOS technology. It contains four independent amplifiers in BTL
configuration. Through the I
2C-bus, diagnosis of temperature warning and clipping level is
fully programmable and the information available via two diagnostic pins is selectable. The
status of each amplifier (output offset, load or no load, short-circuit or speaker incorrectly
connected) can be read separately.
2. Features
2.1 General
n Operates in legacy mode (non I
2C-bus) and I
2C-bus mode (3.3 V and 5 V compliant)
n Three hardware-programmable I
2C-bus addresses
n Drives 4 Ω or 2 Ω loads
n Speaker fault detection
n Independent short-circuit protection per channel
n Loss of ground and open VP safe (with 200 mΩ series impedance and a supply
decoupling capacitor of 2200 µF maximum)
n All outputs short-circuit proof to ground, supply voltage and across the load
n All pins short-circuit proof to ground
n Temperature-controlled gain reduction to prevent audio holes at high junction
temperatures
n Low battery voltage detection
n Offset detection
n This part has been qualified in accordance with AEC-Q100
评论(0)
发评论
下载排行榜
