UDA1351TS pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-07-16
贾伟刚
分享资料个
The UDA1351TS is a single chip IEC 958 audio decoder
with an integrated stereo DAC employing bitstream
conversion techniques.
A lock indication signal is available on pin LOCK,
indicating that the IEC 958 decoder is locked. This pin is
also used to indicate whether PCM data is applied to the
input or not. When non-PCM data is detected, the device
indicates out-of-lock.
By default, the DAC output and the data output interface
are muted when the decoder is out-of-lock. However, this
setting can be overruled in the L3 control mode.
评论(0)
发评论
下载排行榜
