Assmann SuperSpeed USB
USB 3标准(或超速是俗称)采用了全双工通信可以大大提高数据传输速度。以前的USB版本使用了半双工通信。有超高速USB等诸多优点。对于一,通用串行总线是个人计算机的历史上最成功的接口,估计安装基地10 +十亿单位,并在估计每年增长约3十亿单位。这个新版本的一个优点是高速性能的大幅提高,使信号速率高达每秒4.8吉比特;这相当于一一零倍的性能比上届增加USB 2版。快速sync-n-go技术的一个例子是从您的家庭服务器到你的笔记本电脑下载一个25 GB的高清电影。与USB 2,这将需要大约14分钟。与USB 3相同的任务将需要一分钟多一点。此外,USB 3使用更少的电源比以前的USB版本和向后兼容USB 2。然而,用户将不会得到更高的速度的USB 3,除非完整的总线是USB 3。例如,将USB 3打印机插入到USB 2计算机端口会导致USB数据传输速率变慢2。
由于高清晰度视频的到来,存储设备,高像素的数码相机,便携式媒体播放器,等等,为更快的数据传输速率的需求肯定是在我们身上(参见图8本文的末尾)。除了数据传输的速度和效率,超高速USB作为充电中收取你所有的USB设备的两倍以前的USB版本一样快。超高速USB也利用了以前的USB版本的功率传输相同数量的数据分。
The latest version of the USB Charging specification – version 1.2, provides the infrastructure to allow USB to charge devices at up to 5 amps (25 watts) per port; previous versions of the specification only allowed up to 500 mA per port. Speculatively, this will lead to the standardization of device charging, which points to the consumer being able to purchase a single device charger to charge multiple devices. Currently, one often needs several different chargers due to the varying electrical requirements of the device. For example, many smartphones utilize a charger that is rated at 1 A at 5 V, while iPads require a charger that is rated at 2.1 A at 5 V. In addition, this new specification allows the USB host and device to communicate with one another in order to determine the device’s optimal charging capability; USB can then choose from three different ports:
Standard Downstream Port – charging at 900 mA
Charging Downstream Port – charging at 5 A max
Dedicated Charging Port – (no data capability) – charging only at 5 A max
