提高热装LED一致性较高的工作温度
尽管LED制造工艺的复杂性,生产相同色度和相关色温(CCT)的LED是不可能的。相反,制造商将其完成的组件排序成“垃圾箱”的设备紧密匹配的输出。工程师然后根据其最终产品规格选择紧密匹配的产品。
与传统方法的分级的缺点是,LED通常是在任意的驱动电流为350毫安,25°C结温测试(工厂的典型环境温度)。这些参数是满意的商业LED在初期设备进行保守治疗延长寿命,但是今天的强硬的芯片驱动困难和操作温度远远超过用于分级测试的结温。LED色度漂移与温度,所以这种测试和工作温度之间的差异,可以很难选择所需的色度为给定的应用程序。
Recently, however, some pioneering LED makers, such as Cree, have adopted so-called hot binning. Instead of binning their products at 25°C, these manufacturers group their components at 85°C––much closer to today’s typical operating temperatures––improving the precision of chromaticity selection and the consistency of the end products that use the LEDs.
This article looks at the advantages of hot binning and highlights some of the LEDs that benefit from the technique.
