400赫兹电源的电源操作
本文旨在提供一个使用400赫兹电源的工业电源的概况。
大多数大型飞机都装有辅助动力装置(APU),提供一个相位到中性115伏交流电400赫兹的电源。APU是主要用来启动飞机发动机,但也可以用来运行在飞机配件,车上有乘客和飞行前检查的船员时,飞机已经离开了大门。
400赫兹之所以被选在传统的50/60赫兹是因为重量。一个400赫兹的发电机轻得多,因此节省燃料,并需要支持较重的单位,使机身更轻。
mil-std-704f是规格涵盖了飞机电气特性的美国军用飞机,并涵盖了所有方面的要求。
If an aircraft is being serviced on the ground, it is more convenient and safer not to have either the main engines or the APU running. In this case an external 400 Hz generator, or Ground Power Unit, is usually available. Often diagnostic equipment is not required to meet the full flight specifications, and for cost purposes a regular industrial power supply can be chosen.
TDK-Lambda is often asked if one of our AC-DC industrial power supplies will work off 400 Hz input. Usually the answer is “yes”; the following explains why:
For low wattage power supplies (50 W or less), the input circuit is a simple full-wave bridge rectifier (Figure 1)。
