新的LED照片闪光灯驱动程序智能手机摄像头提高图像质量
在智能手机和其他移动设备的摄像头的广泛采用,加上高质量的消费预期,锐利的图像是简单的设计,驱动需要较小的尺寸,并降低元件数量,许多智能手机移动整合前、后摄像头特别。
手机摄像头将增加约16亿个单位在2011到22亿多台,2015,占全球移动电话92%,根据Gartner公司的市场研究公司还发现,手机的一个额外的15%将有两个相机拍人像照片或使视频聊天。
LED驱动厂商正在开发新的设计,以满足这些需求,随着所有类型的集成摄像机移动设备的需求不断攀升。一些供应商甚至开发创新的架构以改善图片质量。
一个例子是AMS AG的as3630照片Flash驱动程序(图1),利用电力从超级电容器。这是说生产4x明亮的闪光输出相比,最闪光的系统在智能手机领域,从而转化为清晰的图像。
Figure 1: The ams AS3630 uses an I²C interface for current and timing adjustments to set the end of charge voltage and measure the Supercap and LED parameters through the internal ADC. A dedicated TXMASK/TORCH input can be used for a torch button or to reduce the battery current if a RF power amplifier (PA) is operated at the same time (TX Masking), (Courtesy of ams)。
Here are the details. The AS3630 can drive up to 8 A current through the flash system, which means pin-sharp image taking and support for faster shutter speeds. Ams noted that photos of fast-moving objects in dark conditions, which previously would have had motion artifacts, might now be captured in detail. It also eliminates glare and discomfort because even short flash durations as low as 10 ms provide sufficient light, according to ams.
