The PAM2862 is a continuous mode inductivestep-down converter, designed for driving singleor multiple series connected LEDs efficientlyfrom a voltage source higher than the LED
voltage. The device operates from an inputupply between 6V and 30V and provides an
externally adjustable output current of up to 1A.Depending upon supply voltage and external
components, this can provide up to 24 watts ofoutput power.
