AD7944,pdf datasheet (14-Bit,
消耗积分:5 | 格式:rar | 大小:224 | 2009-11-21
djelje
分享资料个
The AD7944 is a 14-bit, 2.5 MSPS successive approximationanalog-to-digital converter (SAR ADC). It contains a low power, high speed, 14-bit sampling ADC, an internal conversion clock, an internal reference (and buffer), error correction circuits, and a versatile serial interface port. On the rising edge of CNV, the AD7944 samples an analog input, IN+, between 0 V and VREFwith respect to a ground sense, IN−. The AD7944 features avery high sampling rate turbo mode (TURBO high) and areduced power normal mode (TURBO low) for low power
applications where the power is scaled with the throughput.
评论(0)
发评论
下载排行榜
