微步进电机驱动器AMIS30511C5112RG
消耗积分:0 | 格式:rar | 大小:0.38 MB | 2017-09-07
分享资料个
  Introduction The AMIS−30511 is a micro−stepping stepper motor driver for bipolar stepper motors. The chip is connected through I/O pins and a SPI interface with an external microcontroller. The AMIS−30511 contains a current−translation table and takes the next micro−step depending on the clock signal on the “NXT” input pin and the status of the “DIR” (=direction) register or input pin. The chip provides a so−called “speed and load angle” output. This allows the creation of stall detection algorithms, step loss detection, and control loops based on load−angle to adjust torque and speed. It is using a proprietary PWM algorithm for reliable current control. The AMIS−30511 is implemented in I2T100 technology, enabling both high−voltage analog circuitry and digital functionality on the same chip. The chip is fully compatible with the automotive voltage requirements. The AMIS−30511 is ideally suited for general−purpose stepper motor applications in the automotive, industrial, medical, and marine environment.
评论(0)
发评论
下载排行榜
