1 Introduction
This document describes a non-isolated, power factor corrected, low THD, high-efficiency
LED driver designed to drive a 144 V LED string at 180 mA from an input voltage range
of 90 VAC to 265 VAC.
The LYTSwitch-4 has been developed to cost effectively implement a single-stage power
factor corrected LED driver combined with primary-side constant-current control. The
LYTSwitch-4 controller is optimized for LED driver applications and requires minimal
external parts. It provides control of output current without the use of an optocoupler.
The LYTSwitch-4 monolithically combines the 725 V power MOSFET and controller. The
controller consists of an oscillator, PWM, 6 V regulator, over-temperature protection,
frequency jittering, cycle-by-cycle current limit and other protection features plus a charge
controller for output CC (constant current) control.
The LYTSwitch-4 provides a sophisticated range of protection features including autorestart for control loop open/short faults and output short-circuit conditions. The accurate
hysteretic thermal shutdown ensures safe PCB temperatures under all conditions.
The non-isolated power factor corrected buck-boost design presented in this report
shows how LYTSwitch-4 dramatically simplifies off-line, high-efficiency, power factor
corrected LED driver design and enables an EN 61000-3-2 Class C compliant
implementation of a very high efficiency, high output voltage LED driver.
