5.1W非调光,高效,非隔离Buck LED驱动参考设计报告
消耗积分:0 | 格式:rar | 大小:4.78 MB | 2017-09-08
分享资料个
  1 Introduction
  This document describes a cost effective power supply utilizing the LYTSwitchTM-0 family
  (LYT0006D) in a highly compact buck topology.
  This power supply operates over an input voltage range of 90 VAC to 132 VAC. The DC
  bus voltage is high enough to support a 38 V output when using a buck topology. In a
  buck converter the output voltage must always be lower than the input voltage. The
  output voltage is also limited by the maximum duty cycle of the LYTSwitch-0, which also
  requires the input voltage to be larger than the output voltage.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
