True dual-ported memory cells which allow simultaneous access of the same memory location ■ 16K × 8 organization (CY7C006A) ■ 0.35-micron CMOS for optimum speed/power ■ High-speed access: 20 ns ■ Low operating power ❐ Active: ICC = 180 mA (typical) ❐ Standby: ISB3 = 0.05 mA (typical) ■ Fully asynchronous operation ■ Automatic power-down ■ Expandable data bus to 16 bits or more using Master/Slave chip select when using more than one device
On-chip arbitration logic ■ Semaphores included to permit software handshaking between ports ■ INT flags for port-to-port communication ■ Pin select for Master or Slave ■ Commercial temperature range ■ Available in 68-pin PLCC (CY7C006A), 64-pin TQFP (CY7C006A) ■ Pb-free packages available Functional Description For a complete list of related documentation, click here.
