ATS177 is an integrated Hall effect latched sensor
designed for electronic commutation of brush-less
DC motor applications. The device includes an
on-chip Hall voltage generator for magnetic sensing,
a comparator that amplifies the Hall voltage, and a
schmitt trigger to provide switching hysteresis for
noise rejection, and open-collector output. An
internal bandgap regulator is used to provide
temperature compensated supply voltage for
internal circuits and allows a wide operating supply
range.
If a magnetic flux density larger than threshold Bop,
DO is turned on(low). The output state is held until
a magnetic flux density reversal falls below Brp
causing DO to be turned off (high).
ATS177系列双极锁存霍尔效应集成传感器:是由一个稳压电源,霍尔电压发生器,差分放大器,施密特触发器和输出放大器组成的磁敏传感电路。
产品特点:反向电压保护/电源电压范围宽/易焊性好。
典型应用场合:直流无刷风机/直流无刷电机/高灵敏的无触点开关。
电源电压4.5--20V。
