MC33897单线收发器
消耗积分:0 | 格式:rar | 大小:0.73 MB | 2017-09-19
分享资料个
  The 33897 series provides a physical layer for digital communication using a Carrier Sense Multiple Access/Collision Resolution (CSMA/CR) data link operating over a single wire medium. This is more commonly referred to as single-wire Controller Area Network (SWCAN)。 The 33897 series operates directly from a vehicle‘s 12 V battery system or a broad range of DC-power sources. It can operate at low or high (33.33 kbps or 83.33 kbps) data rates. A high-voltage wake-up feature allows the device to control the regulator used in support of the MCU and other logic. The device includes a control pin that can be used to put the module regulator into Sleep mode. The presence of a defined wake-up voltage level on the bus will reactivate the control line to turn the regulator and the system back ON. The device complies with the GMW3089v2.4 General Motors Corporation specification.
MC33897单线收发器
评论(0)
发评论
下载排行榜
