MAX11044,pdf datasheet (16-Bit
消耗积分:5 | 格式:rar | 大小:444 | 2009-11-26
淡淡的爱
分享资料个
The MAX11044/MAX11045/MAX11046† 16-bit ADCs offer 4, 6, or 8 independent input channels. Featuring independent track and hold (T/H) and SAR circuitry, these parts provide simultaneous sampling at 250ksps for each channel.
The MAX11044/MAX11045/MAX11046 accept a ±5V input. All inputs are overrange protected with internal ±20mA input clamps providing overrange protection with a simple external resistor. Other features include a 4MHz T/H input bandwidth, internal clock, and internal or external reference. A 20MHz, 16-bit, bidirectional, parallel interface provides the conversion results and accepts digital configuration inputs.
The MAX11044/MAX11045/MAX11046 operate with a 4.75V to 5.25V analog supply and a separate flexible 2.7V to 5.25V digital supply for interfacing with the host without a level shifter. The MAX11044/MAX11045/MAX11046 are available in a 56-pin TQFN package and operate over the extended -40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
