dac8811 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-07-28
吴藩
分享资料个
The DAC8811 multiplying digital-to-analog converter (DAC) isdesigned to operate from a single 2.7-V to 5.5-V supply.
The applied external reference input voltage VREF determines the full-scale output current. An internal feedback resistor (RFB) provides temperature tracking for the full-scale output when combined with an external I-to-V precision amplifier.
A serial data interface offers high-speed, three-wire microcontroller-compatible inputs using data-in (SDI), clock (CLK), and chip-select (CS).
On power-up, the DAC register is filled with zeroes, and the DAC output is at zero scale.
The DAC8811 is packaged in space-saving 8-lead SON and MSOP packages.
评论(0)
发评论
下载排行榜
