The PAM2862 is a continuous mode inductive step-down converter, designed for driving single or multiple series connected LEDs efficiently from a voltage source higher than the LED
voltage. The device operates from an input supply between 6V and 30V and provides an
externally adjustable output current of up to 1A. Depending upon supply voltage and external
components, this can provide up to 24 watts of output power.
