开源硬件-PMP20306.2-具有输入电压检测功能的 200V 至 400V 输入(标称值)三路输出偏置电源 PCB layout 设计
消耗积分:10 | 格式:pdf | 大小:417.5KB | 2023-08-02
张鹏
分享资料个
This reference design is a compact and thermally efficient design intended to be used as a bias supply for half-bridge converters. A DCM Flyback with UCC3813-4 controller is used to generate two isolated 12V supplies for half-bridge converter primary driving circuitry. One 5V is generated at the (...)
评论(0)
发评论
下载排行榜
