74HC20 pdf datasheet
消耗积分:5 | 格式:rar | 大小:666 | 2008-08-06
分享资料个
MM54HC20/MM74HC20
Dual 4-Input NAND Gate
General Description
These NAND gates utilize advanced silicon-gate CMOS
technology to achieve operating speeds similar to LS-TTL
gates with the low power consumption of standard CMOS
integrated circuits. All gates have buffered outputs. All devices
have high noise immunity and the ability to drive 10
LS-TTL loads. The 54HC/74HC logic family is functionally
as well as pin-out compatible with the standard 54LS/74LS
logic family. All inputs are protected from damage due to
static discharge by internal diode clamps to VCC and
ground.
评论(0)
发评论
下载排行榜
