MM54HC27/MM74HC27 Triple 3-Input NOR Gate General Description These NOR gates utilize advanced silicon-gate CMOS technology, to achieve operating speeds similar to LS-TTL gates with the low power consumption of standard CMOS integrated circuits. All gates have buffered outputs, providing high noise immunity and the ability to drive 10 LS-TTL loads. The 54HC/74HC logic family is functionally as well as pinout compatible with the standard 54LS/74LS logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground. Features Y Typical propagation delay: 8 ns Y Wide operating supply voltage range: 2±6V Y Low input current: k 1 mA Y Low quiescent supply current: 20 mA maximum (74HC Series) Y Fanout of 10 LS-TTL Loads
