MM54HC266A/MM74HC266A Quad 2-Input Exclusive NOR Gate (Open Drain) General Description This exclusive NOR gate utilizes advanced silicon-gate CMOS technology to achieve operating speeds similar to equivalent LS-TTL gates while maintaining the low power consumption and high noise immunity characteristic of standard CMOS integrated circuits. These gates are fully buffered and have a fanout of 10 LS-TTL loads. The MM54HC/ MM74HC logic family is functionally as well as pin out compatible with the standard 54LS/74LS logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground. Features Y Typical propagation delay: 9 ns Y Wide operating voltage range: 2±6V Y Low input current: 1 mA maximum Y Low quiescent current: 20 mA maximum (74 Series) Y Output drive capability: 10 LS-TTL loads Y Open drain outputs
