AAT4644,pdf datasheet(4-Channe
消耗积分:3 | 格式:rar | 大小:210 | 2010-01-29
王超
分享资料个
The AAT4644 is a four-channel resettable fuse. It utilizes independent current-limited and thermallyprotected P-channel MOSFETs to protect against short circuits. Current limit is factory programmed at 1A. Additional protection is provided with undervoltage
lockout. The switches are turned off when the input voltage drops below a preset level. The
quiescent supply current is typically 20μA. The AAT4644 is a flexible solution, allowing system designers to gang outputs together for lower RDS(ON) and higher current limit.
评论(0)
发评论
下载排行榜
