AAT1276,pdf datasheet(Boost Co
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-29
绝代双骄
分享资料个
The AAT1276 SwitchReg is a 2MHz, 500mA synchronous boost converter with an integrated current-limiting load switch controlled output. The AAT1276 operates from a single-cell Lithium-ion/ polymer battery source and provides a regulated 5V, current limit controlled output to support USB port VBUS applications in portable consumer electronic products. The AAT1276 can support both USB 2.0 host port and USB on-the-go operation, as well as
general purpose applications where a 5V supply with a user programmable current limit is needed.
评论(0)
发评论
下载排行榜
