MCP1802 pdf datasheet
消耗积分:5 | 格式:rar | 大小:777 | 2008-08-07
尚文清
分享资料个
The MCP1802 is a family of CMOS low dropout (LDO)
voltage regulators that can deliver up to 300 mA of
current while consuming only 25 μA of quiescent
current (typical). The input operating range is specified
from 2.0V to 10.0V, making it an ideal choice for two to
six primary cell battery-powered applications, 9V alkaline
and one or two cell Li-Ion-powered applications.
The MCP1802 is capable of delivering 100 mA with
only 200 mV (typical) of input to output voltage differential
(VOUT = 3.0V). The output voltage tolerance of the
MCP1802 at +25°C is typically ±0.4% with a maximum
of ±2%. Line regulation is ±0.01% typical at +25°C.
The LDO output is stable with a minimum of 1 μF of output
capacitance. Ceramic, tantalum or aluminum electrolytic
capacitors can all be used for input and output.
Overcurrent limit with current foldback provides shortcircuit
protection. A shutdown (SHDN) function allows
the output to be enabled or disabled. When disabled,
the MCP1802 draws only 0.01 μA of current (typical).
The MCP1802 is available in a SOT-23-5 package.
评论(0)
发评论
下载排行榜
