TS3A4741/TS3A4742 pdf datashee
消耗积分:3 | 格式:rar | 大小:666 | 2008-08-11
张燕
分享资料个
The TS3A4741/TS3A4742 are low ON-state resistance (ron), low-voltage, dual single-pole/single-throw (SPST)
analog switches that operate from a single 1.6-V to 3.6-V supply. These devices have fast switching speeds,
handle rail-to-rail analog signals, and consume very low quiescent power.
The digital logic input is 1.8-V CMOS compatible when using a single 3-V supply.
The TS3A4741 has two normally open (NO) switches, and the TS3A4742 has two normally closed (NC)
switches. Both devices are available in 8-pin SOT-23 and MSOP packages.
评论(0)
发评论
下载排行榜
