PCA9685 16通道、12位Fm+I2C总线LED控制产
消耗积分:10 | 格式:rar | 大小:215 | 2010-03-08
vinww特烦恼
分享资料个
The PCA9685 is an I2C-bus controlled 16-channel LED controller optimized for LCD
Red/Green/Blue/Amber (RGBA) color backlighting applications. Each LED output has its
own 12-bit resolution (4096 steps) fixed frequency individual PWM controller that operates
at a programmable frequency from a typical of 40 Hz to 1000 Hz with a duty cycle that is
adjustable from 0 % to 100 % to allow the LED to be set to a specific brightness value.
All outputs are set to the same PWM frequency.
评论(3)
发评论
jf_86631870 2020-12-12
0 回复 举报
感谢分享 收起回复
欧鹏翔 2020-11-06
0 回复 举报
感谢分享,学习学习 收起回复
全部评论
下载排行榜
全部3条评论
