uA78S40 datasheet,pdf,Universa
消耗积分:3 | 格式:rar | 大小:83 | 2010-03-09
分享资料个
uA78S40 datasheet,pdf,Universal Switching Regulator Subsystem
The mA78S40 is a switching regulator subsystem, consisting of a
temperature compensated voltage reference, controlled–duty cycle
oscillator with an active current limit circuit, comparator, high–current
and high–voltage output switch, capable of 1.5 A and 40 V, pinned–out
power diode and an uncommitted operational amplifier, which can be
powered up or down independent of the IC supply. The switching
output can drive external NPN or PNP transistors when voltages
greater the 40 V, or currents in excess of 1.5 A, are required. Some of
the features are wide–supply voltage range, low standby current, high
efficiency and low drift. The  mA78S40 is available in commercial
(0° to + 70°C), and automotive (–40° to + 85°C) temperature ranges.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
