The MAX14515 high-voltage liquid lens driver features a high-voltage differential output controlled through an I2C interface. The MAX14515 uses a charge-pump-based boost converter and integrated H-bridge to provide a compact lens driver solution with minimal external components to achieve a small overall footprint suitable for small space constraints inside camera modules.
The MAX14515 features an 8-bit monotonic DAC with a single differential high-voltage output controlled by a 2-wire I2C interface to set the amplitude. The high-voltage outputs are capable of delivering up to 42VRMS (min) into a 220pF liquid lens load at 1.0kHz (min).
The MAX14515 also features two power-saving modes (shutdown mode and sleep mode) to minimize power consumption when the device is inactive. Shutdown mode places the device in a low-power state that resets all registers and disables the I2C interface to reduce current below 500nA (max). In sleep mode, the power-on reset circuit remains active. If no activity is detected on the I2C interface, current consumption is less than 3µA.
Small Footprint for Placement Inside Camera Modules | |
47VRMS Maximum Output (CLENS = 220pF) | |
I2C-Compatible Interface for Setting Output Voltage | |
8-Bit Output Voltage Resolution | |
Guaranteed Monotonic Output | |
±15kV Human Body Model ESD Protection on Outputs | |
Low 500nA (max) Shutdown Current | |
+2.7V to +5.5V Input Voltage Range |
