ADS8254,pdf (Pseudo-Bipolar Di
消耗积分:5 | 格式:rar | 大小:1797 | 2010-06-03
分享资料个
The ADS8254 is a high-performance analog system-on-chip (SoC) device with an 16-bit, 1-MSPS A/D converter, 4-V internal reference, an on-chip ADC driver (OPA), and a 4-channel differential multiplexer. The channel count of the multiplexer and auto/manual scan modes of the device are user selectable.
The ADC driver is designed to leverage the very high noise performance of the differential ADC at optimum power usage levels.
The ADS8254 outputs a buffered reference signal for level shifting of a ±4-V bipolar signal with an external resistance divider. A Vref/2 output signal is available to set the common-mode of a signal conditioning circuit. The device also includes an 16-/8-bit parallel interface.
评论(0)
发评论
下载排行榜
