DAC7615,pdf(Quad, Serial Input
消耗积分:3 | 格式:rar | 大小:499 | 2010-06-08
吴湛
分享资料个
DESCRIPTION
The DAC7615 is a quad, serial input, 12-bit, voltageoutput digital-to-analog converter (DAC) with guar-anteed 12-bit monotonic performance over the –40°Cto +85°C temperature range. An asynchronous resetclears all registers to either mid-scale (800H) or zero-scale (000H), selectable via the RESETSEL pin. Theindividual DAC inputs are double buffered to allowfor simultaneous update of all DAC outputs. Thedevice can be powered from a single +5V supply orfrom dual +5V and –5V supplies.Low power and small size makes the DAC7615 ideal
for automatic test equipment, DAC-per-pin program-mers, data acquisition systems, and closed-loop servo-control. The device is available in 16-pin plastic DIP,16-lead SOIC, and 20-lead SSOP packages and isguaranteed over the –40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
