DIT4192,pdf(DIT4192: 192kHz Di
消耗积分:5 | 格式:rar | 大小:537 | 2010-06-11
分享资料个
The DIT4192 is a digital audio transmitter designed for use in both professional and consumer audio aplications. Transmit data rates up to 192kHz are supported. The DIT4192 supports both software and hardware operation, which makes it suitable for applicaitons with or without a microcontroller. A flexible serial audio interface is provided, supporting standard audio data formats and easy interfacing to audio DSP serial ports.
评论(0)
发评论
下载排行榜
