256级100K的数字电位器 .pdf
消耗积分:10 | 格式:rar | 大小:532 | 2010-06-30
分享资料个
The MAX5413/MAX5414/MAX5415 is a family of dual
linear taper digital potentiometers. Each device has two
3-terminal potentiometers. The MAX5413/MAX5414/
MAX5415 operate from +2.7V to +5.5V single-supply
voltages and use an ultra-low 0.1μA supply current.
These devices also provide glitchless switching
between resistor taps, as well as a convenient poweron
reset (POR) that sets the wiper to the midscale position
at power-up. Each potentiometer consists of a fixed
resistor with a wiper contact that is digitally controlled
through a 3-wire serial interface and has 256 tap points.
It performs the same function as a discrete potentiometer
or variable resistor.
These parts are ideal for applications requiring digitally
controlled resistors. Three resistance values are available:
10kΩ (MAX5413), 50kΩ (MAX5414), and 100kΩ
(MAX5415). A nominal resistor temperature coefficient
of 35ppm/°C end-to-end and 5ppm/°C ratiometric make
the MAX5413/MAX5414/MAX5415 ideal for applications
requiring low temperature-coefficient variable resistors,
such as adjustable-gain circuit configurations.
The MAX5413/MAX5414/MAX5415 are available in a 14-
pin TSSOP package. Each device is guaranteed over the
extended industrial temperature range (-40°C to +85°C).
评论(0)
发评论
下载排行榜
