CY2DL818 pdf datasheet (1:8 Cl
消耗积分:2 | 格式:rar | 大小:555 | 2008-09-03
分享资料个
This Cypress series of network circuits is produced using
advanced 0.35-micron CMOS technology, achieving the
industry’s fastest logic.
The Cypress CY2DL818 fanout buffer features a single LVDS
or a single-ended LVTTL-compatible input and eight LVDS
output pairs.
Designed for data communications clock management applications,
the large fanout from a single input reduces loading
on the input clock. The Cypress CY2DL818 is ideal for both
level translations from single-ended to LVDS and/or for the
distribution of LVDS-based clock signals.
The Cypress CY2DL818 has configurable input and output
functions. The input can be selectable for LVCMOS/LVTTL,
LVPECL, or LVDS signals, while the output drivers support
standard and high-drive LVDS. Drive either a 50-ohm or
100-ohm line with a single part number/device.
Features
• Low voltage operation
• VDD = 3.3V
• 1:8 fanout
• Single-input-configurable for LVDS, LVPECL, or LVTTL
• 8 pair of LVDS Outputs
• Drives either a 50-ohm or 100-ohm load (selectable)
• Low input capacitance
• Low output skew
• Low propagation delay
• Typical (tpd < 4 ns)
• Packages available include: TSSOP
• Does not exceed Bellcore 802.3 standards
• Operation at => 350 MHz – 700 Mbps
评论(0)
发评论
下载排行榜
