SN54AHC05, SN74AHC05,pdf(HEX I
消耗积分:3 | 格式:rar | 大小:505 | 2010-07-11
分享资料个
The ’AHC05 devices contain six independent inverters. These devices perform the Boolean function Y = A\.
The open-drain outputs require pullup resistors to perform correctly. They can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions.
评论(0)
发评论
下载排行榜
