SN54HC125, SN74HC125,pdf(QUADR
消耗积分:5 | 格式:rar | 大小:639 | 2010-07-17
370217
分享资料个
These quadruple bus buffer gates feature independent line drivers with 3-state outputs. Each output is disabled when the associated output-enable (OE)\ input is high.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
评论(0)
发评论
下载排行榜
