SN54LV07A, SN74LV07A,pdf(HEX B
消耗积分:2 | 格式:rar | 大小:458 | 2010-07-19
凤毛麟角
分享资料个
These hex buffers/drivers are designed for 2-V to 5.5-V VCC operation.
The ’LV07A devices perform the Boolean function Y = A in positive logic.
The open-drain outputs require pullup resistors to perform correctly and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions.
These devices are fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the devices when they are powered down.
评论(0)
发评论
下载排行榜
