SN74FB2033A,pdf(8-Bit TTL/BTL
消耗积分:2 | 格式:rar | 大小:375 | 2010-07-22
王超
分享资料个
The SN74FB2033A is an 8-bit transceiver featuring a split input (AI) and output (AO) bus on the TTL-level A port. The common-I/O, open-collector B\ port operates at backplane transceiver logic (BTL) signal levels.
The logic element for data flow in each direction is configured by two mode inputs (IMODE1 and IMODE0 for B-to-A, OMODE1 and OMODE0 for A-to-B) as a buffer, a D-type flip-flop, or a D-type latch. When configured in the buffer mode, the inverted input data appears at the output port. In the flip-flop mode, data is stored on the rising edge of the appropriate clock input (CLKAB/LEAB or CLKBA/LEBA). In the latch mode, the clock inputs serve as active-high transparent latch enables.
Data flow in the B-to-A direction, regardless of the logic element selected, is further controlled by the LOOPBACK input.
评论(0)
发评论
下载排行榜
